waltbennett
Nov 11, 2016Explorer
Searching_Ut wrote:
My only recommendation is to wire the panel so that it bypasses the battery cutoff switch, and make sure the cutoff switch is off when the rv is in storage. A 15 watt panel probably won't keep up with your parasitic losses with the battery connected, depending of course on your particular rig.
Even with your cutoff switch 'off' you'll probably have quite a bit of parasitic drainage. They make them so 'safety' items are never cut off and don't seem to care about batteries. I'd disconnect the positive lead instead and connect your charger directly to the battery.
About Fifth Wheel Group
