harold1946
Nov 14, 2016Explorer
Sam Spade wrote:waltbennett wrote:
Even with your cutoff switch 'off' you'll probably have quite a bit of parasitic drainage. They make them so 'safety' items are never cut off
Not mine. It is a factory "battery disconnect" switch and does exactly that.
It is intended to be used (mostly) when the RV is in storage, unused and un-occupied. At those times, "safety items" are not needed.
THEY ARE NOT ALL THE SAME!!!!!!!
About Fifth Wheel Group
