Greetings all, I apologize if this subject is covered elsewhere, but I couldn't find it if it is. :) Will a 510 watt solar system, (such as Keystone), be enough for Boondocking lights, tv, fans, a...
Usually 500 solar will do it all but the proof is determined by doing an energy use servey (either actual use or desire use) which helps you determine how many battery amp hours you need. That number helps you determine the solar watts...1 amp hour to 1 solar watt is common but don't be afraid of 1 to 1 1/2. Then you can match a controler. Use BIG wire.
