joelc
Dec 03, 2015Nomad
When I go to NC from MA I take I-84 to I-81 and then continue to just out of Richmond, VA to I think 255 that goes around Richmond, then I-64, which leads to I-95, that you can't avoid at that point. Double check the area around Richmond on a map to be sure, I've got the right roads. There are no issues with low bridges, but you do have to go through some mountains in VA and PA. We are in Destin, FL now and you can not avoid I-95 at some point. If you do take this route and need stop over CG I can give them to you. We drive about 3-4 hrs/day.
About Fifth Wheel Group
