hmknightnc
Jul 18, 2014Explorer
tinner12002 wrote:
I think all or most tire stores are watching more about what tire/size that came on the item that the tires are being put on and not wanting to stray from that because of the liability that is involved.
That would or could be a nasty lawsuit for both the trailer owner and the tire store if an LT tire blew out on a trailer that was suppose to only have ST tires and caused an accident causing a death. I'm betting the courts would rule in the victims favor that ST tires should have been on that trailer.
Just my .02 and something I always try to keep in mind.
Huh? ST tires are only rated for trailer use and generally limited to 65mph. They are cheaper and provide higher rated load capacity with less tire material. Not allowed on vehicles because they don't meet specifications for vehicle use.
LT tires are rated for vehicle use and provide lower rated load capacity with more tire material and not derated to 65mph. They far exceed specifications for trailer use.
How are you figuring somebody is going to get sued for using equipment that is superior in performance and exceeds the required specifications for the application?
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
