Golden_HVAC
Apr 26, 2015Explorer
Hi,
The engine, transmission, brakes and probably the rims are the same as a 2014 F-350. The SRW F-350 came with a 11,400 GVWR, and 18" rims rated for slightly more weight than the factory standard 17" rims on a F-250.
That said, you might have the upgraded 18" rims already, or might have some 20" or other silly size rims. Changing to the 18" rims will not increase your GVWR any, but if your rear axle or tires are overloaded when towing, it might help prevent tire failure.
You really need to go back to the scale with full tank of fuel and the fifth wheel. Check the front and rear axle weights. You might be surprised that the fifth wheel is a lot more weight that you expected. Many times the 'estimated pin' weight is just that, a lie. So you might be anywhere from 700 - 1,500 pounds over the GVWR.
That said, I know someone who did the same thing back in 1983 and bought a LTD wagon thinking of towing a camping trailer, only to get home with the car and find out it's tow rating was only 1,000 pounds. Then he bought a F-150 still thinking of towing a travel trailer, and did not like any of those layouts, bought a 24' Wilderness fifth wheel, and towed that home. I have no clue how much weight was on his truck, or it's rating with the 175 HP 351" engine. Eventually he traded up for a dually F-350 with 460" engine rated around 225 HP.
So it is not nearly as unsafe as you might expect it to be when you state 'I am overloaded by 1,000 pounds'.
You should be well under your rear axle weight rating, and probably are under the tire weight ratings too.
Good luck,
Fred.
Good luck,
Fred.
About Fifth Wheel Group
