lawrosa
Apr 26, 2015Explorer
If you want real payload #'s weigh the truck and post axle weights front and rear. Then compare that with the axle weights on the door tag.
Post those #'s here.
Also post your tires max psi and weight they can carry noted on the sidewall.
Air bags are not the best option IMO. You should really add different overload stops as they do with truck campers... These will get you a better ride.
As far as being overweight?? Bad things can happen possibly. Things wear out faster, bearings, mounting points may break, leafs... etc...
You may be better then you think once you get actual axle weights....
About Fifth Wheel Group
