avvidclif1
Apr 26, 2015Explorer
AH64ID wrote:
I never once said to run overload.. go back and read it again!!! I stated that the sticker ratings were underrated. There is a BIG difference, surely you can understand that.
Your truck shared more than the front axle with a DRW of the same year. The Frame, front suspension, brakes, steering, and rear axle are all the same and rated the same. The difference, aside from DRW vs SRW, was rear suspension.
You don't have to believe me but I suggest you do the research yourself before you make more false statements. The information is out there if you spend the time looking, and it's really not that hard to find.
The 2015 air suspension is a perfect example of how what I am telling you is correct. It has weaker main leafs than your 2008 did and airbags... like I said rated at 9,750# RAWR and up to a 37,500# GCWR... Tell the Ram engineers that airbags cannot handle it in a dynamic load!!! Believe what you want to believe, but at least consider at the facts before you make your opinion. Facts should effect opinions, not the other way around.
Now you have spent the bucks on a new truck, so enjoy it!!! Just don't put false information out there to justify your purchase.
There are lots of reasons to get a DRW, but the main reason you claim you did (the rear suspension) was not one of them.
It is possible most of your issue was the tire choice, and not the suspension. Even a 3,750# LRE rated tire is going to have a LOT more flex and give than a pair of 3042# LRE tires. I have ran with LRE tires near their max rating and it indues a lot of movement into the truck and is one of the reasons I now run LRG tires.IDman wrote:
Let us know when you will be hitched up and traveling because I don't want to be anywhere in front of you when you try to stop!
Just because "others do it" doesn't mean it is safe, legal, or right!
That could be the most useless comment of the thread for a couple of reasons.
Mostly because no pickup is designed to STOP the trailer.. the trailer brakes stop the trailer!!!
Have you ever compared the rear end on a dually to a SRW, obviously not. Big difference in the rear end.
About Fifth Wheel Group
