rexlion
Apr 26, 2015Explorer
Phydeauxman, the biggest issue you face IMO is the danger of a blowout from overloaded rear tires. You must weigh the rig and find out where you're at on the rear axle weight. Then look at your tire capacity.
My second concern would be the rear axle capacity, but from other posts here it sounds like it may be the same axle as the 350... I have no idea. If it were not the same, perhaps it could be swapped out. Same thing with suspension, if you wanted to swap out, but the air bags should do the job there.
About Fifth Wheel Group
