JIMNLIN wrote:
Rudyp wrote:
What would any of you recommended the Max I go on a 5th?
Fleet Ford specs says your year model F250 7.3 diesel can tow up to a 13,200 lb trailer which it will have no problems pulling down the road. The truck brakes will stop the truck and the trailers brakes will stop the trailer. If your don't then get the fixed.
Your F250 simply doesn't have the (6084 RAWR) wheels/tires and rear spring pack for carrying a 14k-15k lb trailers pin weight without some serious mods for carrying more weight.
Having made a living pulling 15k GN trailers with mostly LDTs I sure would put a old truck on the road and expect it to last very long pulling that heavy load.
I would stick with Fords 13k max trailer weight and 2500 lb range wet pin weights for your older truck.
Jimnlin,thank you for your response and concern. Yesterday I went to the Ford Dealer and spoke to a Fleet sales person who deals with all there trucks. He brought my trucks info up on his computer ( I gave him my Vin). He then went to a a For website and pulled up fifth wheel towing information and printer me a copy of it. Here is what it states: 7.3 TD ENGINE - THE 7.3 TD ENGINE ONLY COMES EQUIPPED WITH A 3.73:1 AXLE. ALL F-250 7.3TD MODELS WILL ALSO GIVE YOU 10,000 OF CONVENTIONAL HAULING CAPACITY IF YOU HAVE MANUAL OR AUTOMATIC. IF YOU ARE DOING FIFTH WHEEL TOWING WITH A MANUAL TRANSMISSION, THEY ARE AS FOLLOWS: 14,000 POUNDS FOR THE TWO-WHEEL DRIVE, 13,500 POUNDS FOR THE FOUR-WHEEL DRIVE. 13,600 POUNDS FOR A SUPER CAB TWO-WHEEL DRIVE. 13,200 POUNDS FOR A FOUR-WHEEL DRIVE SUPER CAB. 13,300 POUNDS FOR A TWO WHEEL CREW CAB
12,900 POUNDS FOR THE FOUR-WHEEL DRIVE CREW CAB
THE AUTOMATIC TRANSMISSION 7.3 TD HAULS 14,000 POUNDS FOR THE TWO WHEEL DRIVE.
13,500 POUNDS FOR THE THE FOUR WHEEL DRIVE
13,700 POUNDS FOR THE SUPER CAB TWO WHEEL DRIVE.
13,200 POUNDS FOR THE FOUR WHEEL DRIVE SUPER CAB.
13,400 POUNDS FOR THE TWO WHEEL DRIVE CREW CAB
13,400 POUNDS FOR THE FOUR WHEEL DRIVE CREW CAB
