nayther wrote:
Now I'm ugrading the POS speaker they put in that they call a "subwoofer" to a 10" Blaupunkt that I had laying around, not too tough except trying to build a box behind it all through a 9" hole under the refer! Final report when I finish the sub install tonight.
The real kicker is that now I can connect the TV output to the stereo for better sound inside and outside when we're watching SX in the desert via the projector!
Check the output wattage on the radio, you may need an amp to drive the bigger sub.
