RVhiker
Jul 07, 2014Explorer
I use a graphite spray paint called EZSlide, available at Tractor Supply. I can find it readily there, and it is cheaper than Slip-Plate. It has not been tested nor approved by Pullrite, but it has worked well for me for several years.
Slip Plate and EZSlide are spray paints with the "pigment" being graphite; it's used to lubricate and protect the rails on Pullrite Superglide hitches.
You could use it on a standard hitch in place of or in addition to a plastic disc, but it's not necessary in that application and it is somewhat messy to use.
Padlin wrote:
Rookie statement: Never heard of it.
Rookie question: Is this in place of the lube disc, in addition to, or does it perform some other function?
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
