George_H's avatar
George_H
Spare Tire Lift VM
Cable is jammed in sealed unit. Appears that unit is not serviceable and must be replaced. Original unit (2005) is branded VM and made in Mexico, have been unable to locate on www. Mounts to top lip of frame cross member, so would like exact replacement. Any suggestions as to source?
  • I recently had the same problem on my 2004 Carriage Cameo with what sounds like the same hoist system you describe for your rig. I was able to get a direct replacement from Troy Engineering Components and Assemblies (TECA). They are very nice to deal with and if you have your defective hoist in hand when you talk to them, they will send you just what you need. It bolted in directly after I accessed the underbelly by loosening a few screws to spread a gap in the cloth which you must have already done if your hoist is at a shop.
  • TECA illustration might be what I'm looking for, Carriage handle access is through the rear basement compartment. The few local RV parts dealers with any hoists have units set up for access from the side.
    Currently have local fabrication shop attempting to repair original unit.
  • Pick up trucks use a similar system so a auto junk yard may have just what you are looking for.....
