- Sport45Explorer IIDo you need the spare right now? If not, try letting the air out of it. That may relieve enough tension on the mounts that you can shake it around and loosen things up.
- Bird_FreakExplorer IIIs your spare not mounted in there with a lift cable? Mine is and everyone wanting to use hammers and breaker bars made me wonder if yours is different than mine.
- MarkTwainExplorerHook up your trailer, drive it to your tire shop (Les Schwab for me) and then go have breakfast and nice cup of hot coffee:):):)
- tn_terry_tExplorer
ol Bombero-JC wrote:
well where did it say it had not been under there for 10 years?midnightsadie wrote:
if its been there for ten years? you,ll need a bigger hammer. heat pent oil and a breaker bar extension.
The OP's 5th is a 2005.
Where did he say the spare hasn't been removed during his 10yr ownership??..:h
The Mod's advice is xln't.
Allow overnight "soak" time.
~ - ol_Bombero-JCExplorer
~ - midnightsadieExplorer IIif its been there for ten years? you,ll need a bigger hammer. heat pent oil and a breaker bar extension.
- Darryl_RitaExplorerPossibly not Rust. Due to pick-ups losing under-mounted spares, the manufacturers have been forced to place a lock on the cable holding the tire. As the unit goes down the road, the jarring of the highway causes the cable to squeeze down between layers of cable underneath. This creates slack in the cable, which allows the tire to swing. The "cure" has been a clamp that grabs the cable, before enough slack is available to allow swing. The end result is a tire that can't be dropped, without aid from a tire shop or dealership. I'm not sure if trailers have this "feature", but even a little bit of cable squeezed down between the layer underneath can get hung up tight enough to appear to be stuck.
- GMandJMExplorer
gbopp wrote:
P B Blaster also does a good job on rusted nuts and bolts.
^^Yes, this! - drcookExplorerPB-Blaster is one of the absolute best penetrants. Acetone and automatic trans fluid (ATF) mixed together will penetrate rust also. PB-Blaster is what I have been using lately. You might need to get is going with a persuader, then spray some more so it will continue to penetrate. Give it a couple days of whatever product to penetrate the rust, with repeated applications of the penetrant.
- gboppExplorerP B Blaster also does a good job on rusted nuts and bolts.
About Fifth Wheel Group
