- NjmurvinExplorer II
Me Again wrote:
Njmurvin wrote:
At 15k I'd say you're approaching dually territory.
The latest gen 350/3500 SRW trucks will handle it fine. Not everyone wants a duallie!
I realize not everyone wants a dually. I am one of them. Based on my own experience, I'd feel compelled to at least give it serious consideration at 15k. - alboyExplorerMY 15 3500 DMAX with a payload of 3840 toyed with our 15k fiver.
- Me_AgainExplorer III
The latest gen 350/3500 SRW trucks will handle it fine. Not everyone wants a duallie! - NjmurvinExplorer IIAt 15k I'd say you're approaching dually territory.
RollandB wrote:
rhagfo wrote:
Me Again wrote:
Form NADA site.
2003 Arctic Fox
Fifth Wheel Series M-33-5V
LENGTH
34' x 8'0"
AXLES
WEIGHT (LBS)
10050
That weight must be DRY, as Arctic Fox's are heavy units.
Completely agree. My AF which is about 5' shorter gas a GVWR of 13,400 lbs
OK, found document.
Dry axle weight 8620
Dry pin weight 2140
CC 4240
Gross dry weight 10760
GVWR 15000
http://nroa2003.net/downloads/documents.php?dir_id=5
SRW 350/3500 territory!
Chris - rhagfoExplorer III
donn0128 wrote:
Look at the tag on the left front corner. That will give you OE tire and wheel size, axle rating, S/N and GVWR of the trailer.
That is true for newer rigs 2006 and newer, but before that weight sticker will likely be found inside a cabinet door near the sink. - RollandBExplorer
rhagfo wrote:
Me Again wrote:
Form NADA site.
2003 Arctic Fox
LENGTH
34' x 8'0"
AXLES
WEIGHT (LBS)
10050
Completely agree. My AF which is about 5' shorter gas a GVWR of 13,400 lbs - rhagfoExplorer III
Me Again wrote:
Form NADA site.
2003 Arctic Fox
LENGTH
34' x 8'0"
AXLES
WEIGHT (LBS)
10050
That weight must be DRY, as Arctic Fox's are heavy units. - Me_AgainExplorer IIIForm NADA site.
2003 Arctic Fox
LENGTH
34' x 8'0"
AXLES
WEIGHT (LBS)
10050 - n7bsnExplorerI have brochures covering several years, I was unable to find a 33-5V
I was unable to find any 33 ft units
I did find a 36-5V GCW (loaded) 16,400 lbs
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
