LostinAZ
Sep 22, 2013Explorer
We had R & R do an alignment check on our 5th wheel last fall. They did not find that a correction was needed. However in the process they "corrected" the air pressure in our 4 tires which I found very strange as I am meticulous about maintaining pressure at 80 PSI which is the required pressure for our tires. Drove from Spokane area to the Seattle area in 100 degree plus heat on I90. Then decided to have the wheel bearings repacked prior to our fall trip to AZ. Had the tires checked again in that process and found that all 4 tires were 8 lbs low on pressure and had a certified pressure reference to make sure they maintained calibrated devices for pressure checking. Their pressure check matched the pressure check on my electronic gauge that I normally use which I was starting to think was 8 lbs off but it wasn't.
I reported that to R & R immediately. At first they denied that their pressure gauge was off, But after explaining what I had done to verify accurate measurement they said they would check into it. After another follow up by me they finally admitted they had used a defective gauge and that it would be replaced.
On our trip to AZ a couple weeks later we blew out one of the ST tires causing quite a bit of damage to the 5th wheel. It is my belief that R & R is partially responsible for the premature failure of the tire due to their defective gauge.
However, I have not pursued it with them. I hope and trust they have found a new religion about keeping their tools properly calibrated.
About Fifth Wheel Group
