borninblue
Jul 08, 2015Explorer
Sportsman Pin Box Help
We are looking at a 2014 KZ Sportsman S315BHK (new unit). I have a 2014 Ram 2500 with ramboxes. I need to have the sidewinder installed in order for towing to work due to the ramboxes. The problem is the dealer nor KZ can provide me with the model of the pin box so I cannot say for certain if the sidewinder will work. The dealer says the only thing on the pin box is the following:
S315BH
Plant#40
Norco Part#87004
S/N 0016797
After speaking with KZ they stated the pin box "should" be a Dexter because Norco only makes the frame. My question is then why is this sticker on the pin box with Norco's name on it? I looked at the pin box myself and do not see any other markings,but maybe the king pin is blocking it. There is a Mor/ryde king pin attached to the box currently.
The dealer states they would be able to make the sidewinder work with a "spacer" if it does not line up correctly on the box. I am new to towing so not sure about that. KZ says if it is not a direct fit and if modifications have to be made to make the sidewinder work it will void the warranty.....any help would be appreciated!
