SDcampowneroper
Nov 23, 2017Explorer
We have a lot in common. When I was a tie in welder, then tie in foreman , then welding boss ffor OJ we laid Alliance PL around Whitecourt Ab. Jan- Apr. 2000. We camped by the Athabasca bridge, never froze. Batched filled and dumped from the camp water. We had a H/R 32' TT , skirted with vinyl
First I heat traced the water lines with SS 5 w/ ' cable, glued old water ned heaters to the holding tanks, added 1 1/2 pvc 'brick mould' to the frame to allow additional 1 1/2 HD foam insulation. Then put coroplast underbelly on
A neighbor in the camp did the spray foam over his heat traced water systems. It didnt work in the -40c . May have been his set up.
Remember, you must vent all your shower and cooking moisture, use a dehumidifier.
Search for bobs your uncle, pianotuna. These guys from Calgary and On. have also done it.
About Fifth Wheel Group
