So I do now own a Ram 3500 Longhorn Mega cab diesel. I'm currently using it to tow my travel trailer. Want to move to a Heartland Gateway 3650bh which grosses at 15500, dry at 13025 and pin weight a...
The weight your truck can handle depends not only on the truck but also on the weight on the rear tires. That depends on the type of tires and inflation pressure. So weigh your rear end then add the pin weight divide by 2. Then check the pressure chart for you tires and make sure your not over. If you are then a dually is called for.
