Ducky69
Apr 22, 2015Explorer
SRW v. DRW
So I do now own a Ram 3500 Longhorn Mega cab diesel. I'm currently using it to tow my travel trailer. Want to move to a Heartland Gateway 3650bh which grosses at 15500, dry at 13025 and pin weight a...
gtsum wrote:Me Again wrote:
I rule out dually based on my garage size, not wanting or needing a dually for daily driving. The new SRW 3500's with a 7K rear axle rating will do find up to the 17K 5th wheel tow rating if you stay with the 18" tires, which provide a bit of extra capacity beyond the RGAWR. RAM did their home work on this one. The 20" tires have lower ratings and should be avoided by those that want the max out of their trucks.
To OP, as I noted earlier based on year you would be fine, which you are!!! Color me green with truck envy!
Chris
How so on the 20 tires? My 2014 Ram 3500 has 20's and the Firestone tires...3640 rating on each I believe (3640 or 3620, cant recall)..which of course is over the 7k rear axle
