Ducky69's avatar
Ducky69
SRW v. DRW
So I do now own a Ram 3500 Longhorn Mega cab diesel. I'm currently using it to tow my travel trailer. Want to move to a Heartland Gateway 3650bh which grosses at 15500, dry at 13025 and pin weight at 2020. I know the truck can both handle towing weight and payload (hitch) weight.
My only concern is safety for my family in the truck. Can I tow this camper safely? Mostly being used for destinations, but do at least once want to travel the U.S. with it.
Thanks
  • So I do now own a Ram 3500 Longhorn Mega cab diesel. I'm currently using it to tow my travel trailer. Want to move to a Heartland Gateway 3650bh which grosses at 15500, dry at 13025 and pin weight at 2020. I know the truck can both handle towing weight and payload (hitch) weight.
    As others say it depends on which year model and do you have a SRW or a DRW 3500 truck.
    Look on your trucks door post and tell us what your trucks GVWR and RAWR is.
    If you have a 3012 and older SRW has a 6200-6500 RAWR you will have to mod the trucks rear suspension to carry more weight.
    If your truck is a 2013 and newer truck it has a 7000 RAWR and may have enough suspension for a 3000-3500 lb pin weight.
    if I go with 20% of Gross, I'm still under for payload capacity of 5500 on the SRW.
    You say in another post you have a SRW and it has a 5500 lb payload. There isn't a SRW out here that has a 5500 lb payload. If your truck has a 5500 lb payload its is a DRW.
  • If the loaded pin weight is within the weight ratings of the current truck you should be fine.
    There are people who will tell you, you need a dually to tow a pop up.
  • IF you have DRW.......shouldn't be an issue. Pin weight can be 3000# + when loaded for travel
    IF SRW what year and trim?
    I have an 07 3500 SRW....towed 14K 5vr for 7 yrs. My combo was right at ratings (scaled) and never had an issue/concern or white knuckle feeling while towing ALL over the USA
