FireGuard wrote:
I camped at Pismo a couple of week ago with my SRW Ram towing a 21' TH.
I aired all tires down to 20 psi and had no problems.
I noticed numerous DRW also pulling trailers seemed to be doing ok.
I know the idea is to spread the weight as much as possible and a DRW would provide a much wider footprint.
Besides the tires rubbing against each other does a dually do better in the sand when aired down?
Dually 's are the worse in sand, your lucky cause you aired down so much, and you did all the rears. Depends on tire you run also.
Pin it to win it, pismo has blow fine grain sand, that will get ya, has me before. If I'm in the groove I can tow no problem in the deeper sand and I make myself proud.
You did great!!!
