klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
JIMNLIN wrote:
If your '04 F350 SRW is the tow vehicle I think it has a 6800 rawr. You should have your trucks axle weights but many F350 truck from that era rear axle can weigh in the 3300-3400 lb range. This leaves the truck with around 3400 lbs for a in the bed payload. Scaled axle weights can tell you the weight tale on the '04.
New gen F350 srw can have 7230 rawr minus approx 3500 lb rear axle weight = 3600-3700 in the bed payload.
The newer F350 SRW can handle up to around 14k-15k gross weight trailers. Over that and I would want a one ton drw for more rear axle capacity.
Now.... how much pin weight will a good size 5th wheel rv trailer add to a truck.
Much depends on the floorplan.
Also... a bigger player is a tandem axle trailer vs tri axle trailer. Some tri axle trailers have some very light pin weight percentages after loading to the max.
