klr650goldwingExplorerJan 21, 2019SRW vs DRWIs there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
4x4ordExplorer IIIJan 23, 2019Here is some real numbers for a 2017 F350 SRW.GRAWR...... 7230 lbs.Unladen rear axle... 3470 lbsUnladen front axle... 4850 lbsGVWR.... 11500 According to these weights and based on a 20% pin weight my truck can tow: Based of GVWR: Pin weight can be 3180 lbs So Gross trailer could be 15900 lbs based on a 20% pin.Based off GRAWR: Pin weight could be... 3760 Gross trailer weight could be 18800 lbs.
