klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
Hammerboy wrote:4x4ord wrote:
Here is some real numbers for a 2017 F350 SRW.
GRAWR...... 7230 lbs.
Unladen rear axle... 3470 lbs
Unladen front axle... 4850 lbs
GVWR.... 11500
According to these weights and based on a 20% pin weight my truck can tow:
Based of GVWR:
Pin weight can be 3180 lbs
So Gross trailer could be
15900 lbs based on a 20% pin.
Based off GRAWR:
Pin weight could be... 3760
Gross trailer weight could be
18800 lbs.
Did you have the hitch, full tank and occupants in the calculation? I'm assuming so.
Dan
