klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
4x4ord wrote:
I'm not overloaded with 16900 lbs hooked to my SRW.
Front truck axle 4980 lbs ..... empty weight is 4860
Rear truck axle 5820 lbs ..... empty weight is 3480
Trailer axles 14440 lbs ...... pin weight is 2460
Loaded truck weight is 10800 lbs ... the GVWR is 11500 lbs..... max rear axle weight rating is 7230 lbs
