klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
rhagfo wrote:garyp4951 wrote:
I think Ron has a 3:42 ratio, and if I ever go bigger than a 2500 it will be a dually.
Ron has a 4.10, his 2012 had 3.42’s.
4x4ord wrote:Cummins12V98 wrote:valhalla360 wrote:
Yes, the general rule is to pull the ratings for the truck. If you are within the rating...it's good.
NOT really, I can tow 30k or so but in a two axle 5er with 25% pin no way and stay at or under 9,750# RAWR! I look more at what the RAWR is.
I need clarification on your post. You tow 30k with 25% of that on your pin .... so 7500 lbs pin weight, which puts you over your gross axle rating yet you say you look at what the RAWR is?
Edit I think I get it. You're saying you could tow a 30,000 lb goosneck but because tandem axle 5vers oftem put up to 25% of their weight on the pin you would limit yourself by your RAWR when towing a heavy 5ver. So that might drop you down to about a 22000 lb fifth wheel?
