klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
The best way to find out how much weight your vehicle can carry is to subtract the net weight of the vehicle from the GVWR
(located on the driver’s door post). The number remaining is
the maximum weight your vehicle can carry.
4x4ord wrote:
How British Columbia views weight ratings.
Basically:
What are the penalties for driving a
vehicle loaded above its GVWR?
Regulations in BC were recently changed to
address consumer and industry concerns about
the GVWR. If a vehicle, with a GVWR of
5,500 kilograms (kgs), or less, that is
manufactured before January 1, 2001 is loaded in
excess of its GVWR and enforcement officer
deems it to be unsafe, the driver of that vehicle
may be given a Notice and Order. Most light
trucks and RVs have a GVWR of less than
5,500 kgs. If a vehicle with a GVWR of more than
5,500 kgs, regardless of the date it is
manufactured, is loaded in excess of its GVWR,
the driver of that vehicle may be given a violation
ticket. Driving a vehicle loaded above its GVWR
creates a potential safety hazard because the
vehicle’s frame, suspension, brakes and tires are
not designed for weights above the rating the
manufacturer has set.
MFL wrote:While you may not stand under a 12K load on a 10K rope, it is not illegal to do so. He is professing things to be illegal, that he can't back up. So he resorts to slight of hand, obfuscation, smoke and mirrors.Wadcutter wrote:twodownzero wrote:
I can't get into an argument with you about the law because I am a lawyer and I wouldn't want anyone to interpret any of this as legal advice.
I'm sure you have extensive training in truck weight laws. Obviously not from the rest of your response. Please, show one state law in any state where GVWR is a legal weight limit. I'll save you some time - there isn't any.
Manufacturers don't make the law or set legal weight limits.
Maybe you should stick with whatever field of law you practice, divorces, family law, estates, whatever it is. Obviously it isn't anything to do with truck weight laws. Even a poor attorney knows to stay in his own lane when he doesn't know anything about a particular area. At least most do.
While many do not understand the GVWR legalities, I do like the comparison of standing under the 12K lb load hanging from a 10K RATED rope. :E
Jerry
twodownzero wrote:Posting a link to a section of the law on the internet for someone else to read is not giving legal advice.Wadcutter wrote:twodownzero wrote:
Again, I cannot respond to you and tell you what the positive law is in any given jurisdiction because I cannot give legal advice on the internet. I feel comfortable saying that your assertion is not correct and that you should consult someone licensed in the relevant jurisdiction if you want to know what the law is. I am personally aware of at least one state where your assertion is not correct because of the interaction between two laws that you might not realize create precisely the situation you describe--GVWR becomes the relevant limit. And for all I know, there may be more, or it may be an outlier. Either way, traffic laws are not the only thing in play here, and if you hurt someone by operating a vehicle outside of its design limits, you are tempting fate to say the least.
Me Again wrote:laknox wrote:klr650goldwing wrote:
Thanks everyone. There is a wealth of information here. I checked the weight tag on my truck and found the following information: GVWR 9900, FRONT GAWR 5200, REAR GAWR 6830. I don't know how to calculate total towing capacity from those numbers. I bought this truck new. When new it had 3.73 differential gearing. I had those gears changed to 4.56. That increased the towing capacity of the truck, but I don't remember how the truck shop calculated those numbers. Can anyone determine the maximum weight 5er this truck can tow?
It's not what you can TOW, it's what you can CARRY, i.e. PAYLOAD, that's the critical number. Sure, you can tow more, but you can't CARRY any more than you could when that truck rolled off the line. First thing you need to do is to load up your truck as if you were going camping. You, passenger(s), hitch, full fuel and "stuff", then hit the scales to see what your truck weighs. Subtract that from the 9900 lb GVW from your placard. THAT is the PAYLOAD capacity that you have left to CARRY the pin of a FW (or GN). If you =really= want good #'s, then take the FW with you to the scales and weigh =all= axles, steer, driver and trailer, both with and without the FW hitched up. Do it ready to camp to get =real= #'s.
Lyle
Lyle, you missed a very important item. That is weighing the individual axles. Pin weight goes almost 100 % on the trucks real axle.
One wants to get that rear axle weight and subtract it from the RGAWR. That number will tell you how much pin weight the truck can handle. Once hooked up a person should return to the scale and get three readings, Front and rear TV weights and the trailer axle weights. Add all three together to and compare that to the trucks combine weight rating.
Compare the TV rear axle weight to trucks RGAWR and assure the tires weight ratings add up to or exceed the RGAWR. Add the two TV axle weights and if you are in a state that licenses tonnage assure that you have purchase enough for the weight the truck is carrying.
