Hi all... We have a 2012 Voltage 3795 that has already "lost" two of the factory tires. The first one developed a bulge on the sidewall - so we replaced it. The second just had tread seperation (wh...
You probably shouldn't use E-rated LT tires due to load ratings. If you obey the load ratings you're probably stuck with either E-rated ST tires, lousy tires IMO, or G-rated LT tires if the wheels are rated for the higher pressures. Or you can change to 17.5" wheels and tires. Ya pays yer money, ya takes yer cherce.
