NMDoyle
May 22, 2013Explorer
ST or LT tires?
Hi all... We have a 2012 Voltage 3795 that has already "lost" two of the factory tires. The first one developed a bulge on the sidewall - so we replaced it. The second just had tread seperation (wh...
joebedford wrote:
I ran a lot of miles on my old trailer with Goodyear G614s aired to 110psi. They did NOT wear in the center of the tread - the only wear they showed was on the edges of the tread. In fact, I even went so far as to borrow someone's tire gauge to make sure I wasn't underinflating by error because there was no center wear.
I'm running 80psi on my current tires and the only wear they are showing is on the edge of the tread.
Go figure...
