Me_Again
Apr 08, 2017Explorer III
alaska511 wrote:Me Again wrote:alaska511 wrote:
I just ordered the GoodYear Unisteel G614RST 14 ply.
I don't think I can do a lot better than these.
Those tires are very big over kill for a trailer with a GVWR of a little less than 12K. Michelin XPS Ribs or Bridgestone Duravis R250 would have been a much better match for a lot less money.
The trailer loaded comes in heavier than the GVW on that ridiculous sticker. This has been the case with nearly every RV I have ever seen. Call the weight police. Overkill truly is what I was going for. I don't want to worry about it, and we have some rough roads to travel.
"Better match" opinions leave a lot out of the equation.
To each their own, however I had a similar size and weight 5th wheel for 11 years. With only 10K on the axles, the G614 will beat the trailer up if you inflate them beyond around 80 pounds. I ran 71 pounds in both my ribs and R250s. Ribs were on it for 6.5 and 40 some thousand miles. I sold them on CL for 200 bucks and installed R250's, which I also ran at 71 lbs of inflation. Wear was even and handling great.
BTW, your wheels may not be rated for more that 80 lbs inflation anyway.
Chris
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
