brirene
May 04, 2015Explorer
ST to LT
I know for sure this has been asked and answered hundreds of times, but have you ever searched "tires" or various derivations in the fifth wheel forum? Either no matches or 244 pages! To the point...I...
bluka43 wrote:
x4 for Bridgestone Duravis 250's. Like one poster mentioned. Pay particular attention to the spacing between the front and rear tires. If the spacing is rather close and you're running GY Marathons like I was, you'll want to find a tire that will have the same overall diameter of the Marathons. A GY Marathon ST235/80/16 E is 30.7 Inches in diameter and the Bridgestone Duravis R250 is 30.7 Inches in diameter. I chose to go with the Bridgestone 245/75R16. The Duravis is slightly wider in this size, but most RV's have enough fender well room to accommodate that small difference. I had so many problems with Marathon belt separations through the years that I don't care to repeat. Since I switched, I have never looked back, literally. Here are some tire specs between the above mentioned tires.
Goodyear Marathon Radial ST235/80R16 Tire Specs
Diameter 30.7"
Width 9.2"
Tread Depth 10/32"
Tread Width 6.8"
Rim Range 6-7.5"
Load Range E
Max Load 3420 Lbs
Max PSI 80 PSI
Weight 34 Lbs
Revs/Mile 679
Bridgestone Duravis R250, 245/75R16 Tire Specs
Diameter 30.7"
Width 10"
Tread Depth 14/32"
Tread Width 7.3"
Rim Range 6.5-8"
Load Range E
Max Load 3042 Lbs
Max PSI 80 PSI
Weight 57 Lbs
Revs/Mile 679
