brirene
May 04, 2015Explorer
ST to LT
I know for sure this has been asked and answered hundreds of times, but have you ever searched "tires" or various derivations in the fifth wheel forum? Either no matches or 244 pages! To the point...I...
Me Again wrote:brirene wrote:
OP here. The 11.5k is on the scale. Gvwr is 12950, gawr 5k.
So you are saying that the trailer as you use it weighs 11,500 which includes pin weight, right?
It is a little strange that the GVWR is 12,950 and has 5K GAWR. That would give you 10,000 capacity on the axles and would be 2950 pin weight to max GVWR. That would mean a 22.8 percent pin weight.
So you sure you read and/or post the correct numbers?
The last year I can find for the model in 2004 and it states GVWR as 12500 lbs.
Chris
