Endricken's avatar
Endricken
Stay away from BFG Commercial T/A Tires
In years past and sometimes recently these tires were recommended.
I now believe that's bad advice!
I ended up with 4 eventually. My 2411 BFG Commercial T/A Tire was recalled two years ago (Aug 2012).
My two 0909 BFG Commercial T/A 235/85R16 tires failed within a month of each other in Nov 2012 with one having a non catastrophic sidewall delamination (Tire held) air, and its mate blowing its tread completely in Dec 2012 (one hour after checking tire pressure). Filed a claim with BFG, not their fault...
BTW, I always check air pressure when departing.
My remaining/last 3209 BFG Commercial T/A tire failed this week (total tread delamination). I was going to replace it in August, but it beat me to the punch. It was fully aired up 2 hours before failing.
Wow, 3 tire failures (two premature, one at almost 5 years) and one Recall - "Mothers, don't let your children do what I have done..." :)
I sure hope the replacement Michelin LTX MS 2 tires hold up better and last more than 3-4 years...
  • x2-Me Again- My 40ft open Road would eat tires and it wasn't coincidental that 3 of them happened within hrs of jumping a curb, which I hated to do but sometimes ya cant help it. I put goodyear G rated tires on it and done. But I recently purchased a 2002 HR Presidential came with GY wrangler HTs, rated at 3095 per tire 2500 hitch wt, UVW 11,500, gvw 15,000 These numbers don't add up folks!! And that's why u need G rated tires or an extra axle. Wiggle room!!!
  • Have you ever weighed your trailer? How many curbs and big pot holes have you hit? Not trying to deminish your tire problems, but there is often more to a story than what is initially told.
  • They(BFG) just need to add a Nylon Cap and they will be good to go!
    There are only two LRE 16" tires I would put under that trailer. R250s or XPS RIBs. You have a large trailer with 6k axles that should have had 7K axles and LRG tires. Chris
