time2roll
Nov 21, 2019Nomad
Rockinfigs wrote:This is an issue of the transfer switch having power off for a few milliseconds before connecting to the other source of power.
So I did a Lil test I had the inverter on n turned tv on.. Then I turned on the gen n waited for the gen to convert over.. When it converted over to gen the TV shut off..then I did the opposite.. Had the gen on n inverter turned off.. Had tv on.. Then I turned inverter on n shut down the gen.. Same results
Not sure what all is connected to what but you could reconfigure things so that you run the tv-satellite-dvd etc full time on inverter power regardless of the generator or utility power status. Basically you need to change the priority so the inverter power always goes direct and is not switched when other sources are presented.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
