Rockinfigs's avatar
Rockinfigs
Still confused about inverter n gen
So I have a 2020 attitude 3218mm..i have a xantrax 1800 pro inverter, 2 solar panels n solar charger. When I bought my rig I took it in to eclipse for some warranty work.. They advised me to turn inverter off before i turn on gen(Onan 5500) n vice versa.. Turn gen off before turning on inverter. Now when this is done it interrupts my outlets which interrupts my TVs while watching. But I've been told I should have a automatic transfer switch built into the inverter n I should be able to leave inverter on while running the gen.
Can anyone with newer attitudes confirm this pls thks
  • That’s odd- maybe newer televisions are more sensitive, but why can a $80 ups switch fast enough for all electronics to stay powered up, but a thousand dollar inverter will not?
    Regardless, I’d have the electronics on a ups, set to not beep on power interruption ( we have 5 with all of our electronics on them at home).
  • Rockinfigs wrote:
    When it converted over to gen the TV shut off.
    How long of a shutoff are we talking about?
  • A UPS doesn't switch. Its battery is being charged or not but the output is always driving the loads.
    Yep, or else the "U" wouldn't stand for "uninterruptible".
  • yes, an UPS is the only way to truly have uninterrupted power. I have a 2,000 inverter and 50 amp auto transfer switch from Bestconverter (Boondocker). Don't remember which way but going from/to generator there's a delay, the other way not but either will drop power long enough to my satellite receiver that it must reboot.
  • nayther wrote:
    yes, a UPS is the only way to truly have uninterrupted power.
    I guess an inverter that's always on would qualify.
    There are different types of UPS. Only the ones that convert AC to DC and then DC to AC don't interrupt the power - ie used in more critical applications so think more $.
    The specs on the 900W Cyber Power unit for example indicate a 4 ms transfer time which is rather short and hence the switching may not effect most connected electronics. One AC 60 HZ cycle is 16 ms.
    What is the definition on uninterruptible?
  • When a RVer connects a non switching inverter to the battery then they have a uninterruptible source - AC charges the house battery and the house battery powers the inverter which is now independent of the battery charging source.
