4x4FF's avatar
4x4FF
Storage Box Input
Hi All,
I am looking for ideas/input on a under chassis storage box I am going to make for my 5er. First off what I am looking at accomplishing is storing my Ladder and BBQ Grill. If I can get those 2 items out of my 5er's basement it will help out tremendously. Before it starts I realize that I could eliminate a lot of my stuff and not have a problem with room. That is not the point of my question. I want to be able to store these things outside of the basement if possible. I am looking at building an 8" X 24" storage box to mount under the frame rails out of 3/16" aluminum. It will have a door access on both sides (One side to pull out the ladder the other side for the Coleman grill and maybe the patio rug). I have done all of the measurements and it will all fit.
My question is in the picture below I have shown the approximate location. Do you guys have any input on problems I may encounter by locating it there? I sit high enough that I think it will work ok but I just want to make sure I haven't missed something.
The yellow line is where I propose to mount it.
  • Dragging it/banging it/whacking it would be my concern when transitioning curb-ways/driveways/angled sites/some roadways.
    I'm just surprised at all the stuff that folks carry.
    We Full Timed and EVERYTHING we owned was with us. We'd pull into a site, set up and then watch weekenders set up. It was like a circus clown car...stuff just kept coming out and coming out and coming out. :B
    All of our stuff packed up I could open any compartment and see it all.
    But hey....your rig...your stuff.
    Nice box & sewer storage. New one will fit right in...just concerned about road clearance.
  • slomark wrote:
    I've just completed the installation of a undercarriage cabinet, 40"w x 9"h x 11' long. It terminates in front of the axle, and carries a port note (a folding boat).
    Not wanting to stress the already flimsy frame, I fabricated some .125" angle iron with mounting plates that bolt into the I-beams. From that I hang the two 11' trusses, and bolt angle iron across the bottom every 30", used .375" ply on the bottom with a laminate flooring to reduce scratching, and used coroplast for the sides.
    Hope this helps.
    Bet you meant 10ft Porta-Bote ;-)
    Hope this helps.
    How far forward (Towards the front) does it go. My only fear is dragging the compartment when transitioning up hill since mine will be so far forward. Mine will end about 32" behind the landing gear.
    Steve
  • I've just completed the installation of a undercarriage cabinet, 40"w x 9"h x 11' long. It terminates in front of the axle, and carries a port note (a folding boat).
    Hope this helps.
  • DutchmenSport wrote:
    Correct me if I'm wrong, but do you mean (8" X 24") 8 x 24 (feet or inches?) Double quote is inches. Single quote is feet.
    If inches, that's pretty small, only 8 inches by 2 feet? But, 8 feet wide by 24 feet long, that's pretty big?
    The dimensions of length and width are not so critical. However, (if 8 x 24 feet) and you have to access under the floor, you may have a challenge removing the box (which may never happen).
    I'd be more concerned about how "deep" the box is. You need to make sure you have enough clearance between the bottom of the box and the road so you won't drag it. So it really depends upon how "deep" you make it.
    Your idea should work, I don't see any reason why it should not. It looks like you already have a storage container under there. If you go with the same depth, I don't think you'll have any problems. with either ... 8 x 24 inches or 8 x 24 feet!
    The box will be 8 inches tall by 24 inches wide by approximately 8 feet deep. So basically from the side view it will extend down 8 inches from the frame (approximately the same depth as the other storage mounted there) and be 24 inches wide as shown in the yellow square on the picture I posted. It will also extend across the 5er and be accessible from either side hence the 8 feet.
    Steve
  • Correct me if I'm wrong, but do you mean (8" X 24") 8 x 24 (feet or inches?) Double quote is inches. Single quote is feet.
