4aSong
Jul 15, 2019Explorer
We built our RV garage some 5 years ago and overall have been very satisfied with the finished product. Our is nowhere near the size you are planning as our was a drive thru 24 x 36 garage. I have noted in RED some items to consider.
- It is going to be metal building about 65 deep by 42 wide in back yard behind fence. Will probably change from RV gate to large sliding gate or maybe just add another RV gate.
- Two 16' wide by 14' tall doors
- Concrete floor and driveway
- Air conditioned is not in the budget so will have to do without. Being in Arizona (Phoenix) you may want to reconsider A/C. as it will be cheaper to install it during construction than later.
Some thoughts/questions:
- The 65' deep is so can keep truck attached or have rear door access even with a '43ft rig. This barely fits in yard depth wise so open to other configuration or wider rather than deep if have not found the extra length useful.
- Will have it wired up for 50A and for a welder if ever get into that along with other 110V outlets. Lights too. Not sure of anything specific to consider.Consider both 110/220 and add outlets for future needs. You never have enough outlets.
- Does an area for working, welding, etc. really best to be separate with walls or do curtains, etc. work well to keep the rest of garage fairly clean? we dont have a separate area. overall the garage stays relatively clean even when I have other projects going on.
- What about RV dump? Just do it to street in front of house? I am on septic. Shop will be downhill of septic so would have to do pump to push up hill if run it to the shop. Not sure if practical to run it into shop so could keep in shop for guests etc. plugged in.
- In general does it make sense to have rig in shop for guests or really need to pull it out so not in enclosed building (can always open big doors too) We have had guests stay in the RV while in the garage as well as have used it when out of garage.
- Not sure how much will miss water if don't run it or just do a single connection from garden hose from house or similar. We have a water source within 30' of garage so did not add a new line.
- Anyone ever put solar on roof of metal building? Thinking of adding solar to house anyways so not sure if on shop would be better alternative or just do on the house.
Thanks for any input as trying to get it right first time but also on a budget ...
A requirement when we built ours was to be able to have all slides open and awing open when in garage. In addition room for both truck & trailer.
Consider Air lines placed throughout so you have access to compressed air for the shop.
Consider drains so when washing indoors water has a place to go.
This is my 2cents worth and i'm sure others will chime in with their recommendations. :)
About Fifth Wheel Group
19,040 PostsLatest Activity: May 21, 2026
