donn0128
Oct 06, 2015Explorer II
Colo Native wrote:donn0128 wrote:
Have you tried with a gas match? Over the years there has been a few times when the pizzeo igniter would not work. Ot always turned out to be a loose wire. If there is no gas flow with the burners on, then, since there are four gas valves you have no gas to the stove.
No gas , used a lighter nothing worked
Then there are only a couple of options. No gas! Or you have a gas leak detector that has killed your gas flow, or you have air in the lines that needs to be purged out. Turn on one burner, hold a lit gas match to the burner until it lights. This can take up to two minutes.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
