laknox
Mar 25, 2016Nomad
Straight from B&W
OK, guys. Here's the straight scoop from a B&W engineer. As I contended in another thread, he said that the Turnover Ball base and Companion FW hitch =system=, carries the vast majority of the pin l...
laknox wrote:
OK, guys. Here's the straight scoop from a B&W engineer. As I contended in another thread, he said that the Turnover Ball base and Companion FW hitch =system=, carries the vast majority of the pin load through the hold-down receiver and into the TO Ball base and to the truck frame. The feet of the Companion =stabilize= the lateral forces to the bed and carry very little of the pin weight. He called them "outriggers, in effect". Doesn't matter that there's a certain amount of tension on the draw-down bolt, or not; you have to look at the entire =system= to see where the forces are acting.
Again, this was direct from a B&W engineer and not something I pulled from the same place that RV dealers pull MSRP numbers.
Lyle
