bren99's avatar
bren99
Strange Kitchen Sink Problem
I have a double kitchen sink in my fifth wheel. If I run water in the sink it will not drain. I have let it sit a couple days and I look and the water is gone. If I run water again, it will not drain out. I have tried everything for sink clogs, used a snake and nothing happens or changes.
Has anyone run across this before? The sink is either clogged or it isn't, so why does it suddenly drain all the water out?
I need my sink back! Any ideas?
As a side note, my bathroom sink and shower drain fine.
  • Does trying everything include disassembling the drain pipe?
    bren99 wrote:
    I have let it sit a couple days and I look and the water is gone....The sink is either clogged or it isn't, so why does it suddenly drain all the water out?
    How would you know it suddenly drains out unless you sit there and watch it? I must be missing something.
  • lovetotow wrote:
    Maybe your sink roof vent is clogged causing an air lock
    X2.Try running some water down the roof vent to clear any clog.
