rich and char wrote:
Its in the hydrolics of the 6 point leveling system , Mine has been doing it for the past 2 years as well as many others , lippert is aware of it , and a recommendation of removing a quart of hydrolic oil and replacing it with a quart of another type of oil , my memory escapes me , its been a while. If I come across it I'll post back.
Ok , found the PDF from Lippert , How do I post it on this for
um ?
I have been putting up with the creaking from my 6-point leveling for over a year. It occurs when there is a temperature change.
According to the order they put out you can purchase a quart of one of the following:
Torco RFF Grade 15, Maxima Fork Oil Grade 15, Cat Hydraulic Oil Additive 1U-9891.
You are suppose to pull your hydrolics in (slides/stands) so that your reservoir is up to the full line, then use a turkey baster to take out a quart, then put the new quart of additive in.
