Doughboy12
May 20, 2013Explorer
This situation is the ONLY time I would recommend putting it on a center stand. The box kind that go under the Frame/motor that you use to work on them.
I would NOT tie it down with the suspension in compression...too much force is going to do two things. 1. blow out your seals and 2. come loose from the forces of oscillation.
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
