fj12ryder
Mar 27, 2016Explorer III
joebedford wrote:No way I can think of right off hand. I will say that mine seem to stay in sync okay, since when I retract them they come off the ground together. I would think if there was an issue with them operating at different speeds it would be noticeable after a few uses when you noticed that they don't leave the ground at the same time.fj12ryder wrote:I've always wondered if there is a possibility that these dual motor systems can run at different speeds and twist the TH frame.
I replaced mine with the Bulldog System
Is there anything to sync the two motors?
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 26, 2026
