If you are traveling in sub-freezing weather: 1). Will the furnace work while on the road? 2). Do you run the furnace while going down the road? Thanks in advance
We travel a bit in cold (sometimes below zero) temperatures, with water in the unit, so yes....the heater is on. And as previously stated, be sure to have at least some of your vents open to flow!
