If you are traveling in sub-freezing weather: 1). Will the furnace work while on the road? 2). Do you run the furnace while going down the road? Thanks in advance
My vents will not be covered when the slides are in. In the living room, theer is no way it could be covered. In the Bedroom, the sheets/blankets could possibly slip and cover a vent. I will make sure that they cant.
