IOWASTROKER
Nov 17, 2013Explorer
Suburan furnace?
Six year old Surburan 42K BTU. Replaced computer board once and blower motor 3 times. Noticed last night it seems the high limit switch is acting up. During a normal cycle, burner will ignite on and off several times. Once RV is up to pre-set temp, furnace will NOT come on until I switch thermostat off, then on....so when I got up this AM...it was really chilly. Thank goodness for some cheap electric heaters:))
BTW: Had to braze a crack in heat exchanger last time the motor went south.
You furnace gurus will probably suggest: buy/install a new one. When its 10 below zero, it runs 24/7...and 12-volt motors can NOT handle that kind of use...right??? THX and have a great Thanksgiving. Johnny...currently in Iowa.
