- EtstormExplorerThe sofa bed in my fifth wheel was horrible and I tried everything.
When traveling back from an assignment, I went under a low bridge and totaled the trailer. Now I have a new trailer with a great sofa bed.:S - rockhillmanorExplorer III had the SAME thing happen to mine. It's not just the need to reinforcing it it is the whole darn workmanship of the whole frame from the manufacturing.
Called a Mobile RV repair guy. Said he sees this happen all the time.
His Fix?
Well he took the whole couch out and showed me all the cheap thin particle board that holds these couches up and attached to the wall. Most was split and just shredded. Screwed with screws way too short etc etc.
He ripped it all out and He built me a frame with 2x4's and screwed it back together with screws the correct length.
Couch was like brand new and even sat up higher and opened an closed better than when I bought it.
Whole thing took about an hour or so and the repair bill was so cheap I gave the guy a bonus!
My advice is Call Mobile RV repair they see this cheap workmanship the manufactures use over and over again and know how to fix it. :C - laknoxNomad
gbopp wrote:
laknox wrote:
Stefonius wrote:
Agree on the plywood. A sheet of 3/4" A-grade plywood under the cushions makes for a VERY "butt-friendly" seating surface.
Carry a couple folding saw horses and you've got a spare dining/gaming table, too. :-)
Lyle
Is a portable bar. :)
Sure; just the right height for training the kids to mix drinks. :B:B:B
Lyle - gboppExplorer
Lyle
Or a portable bar. :) - Cummins12V98Explorer III
Johno02 wrote:
A piece of plywood does wonders.
On my list to do. I have heard that is the way to go many times. I plan to replace the foam in the seats with some QUALITY foam. - laknoxNomad
Lyle - StefoniusExplorerAgree on the plywood. A sheet of 3/4" A-grade plywood under the cushions makes for a VERY "butt-friendly" seating surface.
- jserv61ExplorerPlywood sounds like a good idea.thank you.
- csamayfield55xExplorerwe used blankets folded up evenly inside the folds of the mattress. Worked very well
Chris - Johno02ExplorerA piece of plywood does wonders.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
