SUMRX4's avatar
SUMRX4
suggestions on models
I am looking to "upgrade" my RV. I would really like a fifth wheel because of the ease of handling and maneuverability. My TV is a 2003 Super duty with the 6.0 diesel. Its a diesel but with it's age it's towing capacity is only 12,500lbs. I am having trouble finding 5er's under that weight that aren't designed as 1/2ton towable. My issue with 1/2 ton 5ers is I'm 6'2" tall and they all seem to have very low ceiling heights in the bedroom. Does anyone have any suggestions for a model within my tow specs that has a full height ceiling up front?
  • Our Grand Design 290BH has about 6’-6” or maybe 6’-8” max height in the bedroom, except for the step right near the bed. So basically, you can maneuver around around the BR just fine, but have to crouch right before getting in the bed. I’m 6’-3” and this is no problem at all. Our rig is marketed as a 1/2 ton towable, but it runs up into the 11K range when loaded.
    As usual, it's not the towing capacity, it's the PAYLOAD that's the limiting factor.
    Lyle
  • Some Montana High Country models would be in your range. My 305 RL is in the 12,500 loaded range and pulls easily with my 2013 Ram 2500diesel
  • cougar28 wrote:
    Our Jayco HT has a 74" bedroom height. I'm also 6'2" and have no problem with it. Maybe I just got use to our old 5er we had for 17 years that was way lower.
    Apparently different models/years are built different. I was in an HT a couple weeks back and while it was higher than some others I had looked at it wasn't tall enough for me to comfortable.
  • 1/2 ton towable is a marketing term that has nothing to do with actual weights and sizes. Plus 12k is beyond 1/2ton trucks.
    Our current 5er is GVWR around 12k lb. I think it's considered mid-height for the bedroom. I'm also 6'2" and just fit...but in the main living area, I can't even touch the ceiling.
    I'm 6'3" and had no problem with the bedroom in the Cougar half ton we looked at. Brochure says 7' ceiling but if I remember correctly that's max height in the bedroom.
  • Our Jayco HT has a 74" bedroom height. I'm also 6'2" and have no problem with it. Maybe I just got use to our old 5er we had for 17 years that was way lower.
  • A fiver approaching 12,000# is not 'half ton towable', I don't care what anyone says. I feel your pain though, at 6' I am cramped for space in the nose too.
  • The term you are looking for in your search is "Full Profile" Fifth Wheel. "Full Profile" will give you the 6 (plus) foot front you are looking for. Sorry, I cannot give you anything specific on a make/model/year that would have a full profile front and still be 1/2 ton towable.
