tom1948's avatar
tom1948
Sunnybrook hot water electrodes
I am trying to help a friend who owns a SunnyBrook fiver and he says the electric hot water doesn't work. I pulled both the red and brown wires in the outside panel from what I think are going to the electrodes to test with an ohm meter. He thinks the electrodes are behind the metal box under the sink. I am now thinking that the wires outside are too small in gauge to run a hot water heater. They look like 12v.
Do we need to remove the metal box under the sink? There is an on/off switch on the metal box as well as on the wall.
  • Red and brown wires are 12V DC and go to t-stats
    Electric element uses 120V AC power.
    Element and wiring are under the cover on backside of tank
    The ON/OFF switch on cover needs to be in ON position for electric element to work
